| The green ones are called bump stopper. The part number is 46512-H0101. If your Z is an auto, I think you only need two (on the brake pedal). If it's a 5 speed, I highly recommend you replace all of them at the same time. The clutch pedal have 3 of the green bump stopper (2 on the pedal and 1 near the firewall). The clutch pedal have another bump stopper that looks like a plastic clip of some sort (part number 46543-Q0400). Replace all 5 of the green bump stoppers (2 on brake and 3 on clutch pedal) and the black plastic clip on the clutch pedal.
